Hello, i just downloaded Usine today and it seems very interesting.
however, i'm stuck at page 50 of the manual.
I've made the stereo delay, but can only save it as a patch, and not a sub patch (shift+ctrl+S doesn't works, and 'save sub patch as' is always greyed).
When i drag 'stereo delay.pat' from the library menu holding ctrl it loads a patch, in structure view and with a '1' instead of an 'S'.
Am i doing something obviously wrong?
Thanks for reading.
p.s.:
I hope my english is not too bad.
EDIT: i just realized i had to hold ctrl _before_ dragging... sorry for this dumbness! :rolleyes:
Edit: solved! (was: saving sub-patches greyed)
- senso
Don?t worry for your English.
In fact there is no difference between patch and sub patch. Any patch can be a sub patch.
For example: Save your patch as ?my first delay.pat?, open the Library browser (after a rescan) and drag and drop this file onto the patch panel while press CTRL.
A sub patch is created.
