hollyhock physics example to midi
gregh
Unread post by gregh » 18 May 2013, 04:26
hi - i have probably missed something already there, but I would like to output midi notes from the Hollyhock physics engine example, rather than trigger samples as is the case now. Is there a tute that covers something like that, or an older add-on that I could deconstruct to give me some tips
thanks, greg
Unread post by nay-seven » 18 May 2013, 08:37
here an example, up is the current patch , down the midi version with a Plug-in, of course you can use buses if you want have your plug-in in an other rack.
*You can add faders to min and max inlets of the last change scale to set midi note range.
gregh
Unread post by gregh » 18 May 2013, 09:43
thanks - this will give me a great start to experimenting with patching. Much appreciated
Greg
Unread post by nay-seven » 18 May 2013, 10:50
if needed you also have a chapter about my first patching in the manual online
gregh
Unread post by gregh » 21 May 2013, 13:52
here is my attempt to copy your patch nay-seven. I get no sound when the ball is bouncing around, althoug I do get a sound when I play a key on the synths (so audio works). I have no doubt it is something silly I have done, but if yu could help that would be great.
http://www.sensomusic.com/forums/upload ... 0patch.pat
thanks again, gregh
Unread post by nay-seven » 21 May 2013, 15:03
yes, you have use 0..1 values for all faders, but midi note, velocity are 0..127, length are in milliseconds..
here an example I've improved
download
gregh
Unread post by gregh » 21 May 2013, 15:22
thanks nay-seven - works fine now :) I shall make a copy and pull it apart to see what the bits do
gregh
Unread post by gregh » 22 May 2013, 08:54
returning to this - I am struggling to understand he design philosophy - for example what does "delete patch" mean. When I see something like that I think it will mean that if I have a patch selected in a rack and hit delete patch, I will remove that patch from the rack. But nothing happens, so what is 'delete patch' for in that context?
Unread post by nay-seven » 22 May 2013, 09:07
A way to have 2 patch running is to copy this patch and create 2 sub patch in parallel..?
the delete patch button don't work on this version, fixed on next one (soon)
gregh
Unread post by gregh » 22 May 2013, 09:09
thanks again nay-seven - I am struggling but see the potential and appreciate your quick help
gregh
gregh
Unread post by gregh » 22 May 2013, 09:17
quick update - the subpatch thing worked a treat - thanks again
