harmonic eq
trik
Unread post by trik » 15 May 2013, 14:55
I made a 6-band harmonic equallizer.
It takes a note from the midi input and applies a notch filter to the audio input on the frequency of this note and its first 5 harmonics.
When the gain+- is set to a positive db value it can be used as a simple vocoder.
When the gain+- is set to a negative db value it can filter out frequencies of a melody played in another track.
http://www.sensomusic.org/downloadaddon ... eq_v01.pat
Known bugs:
click noise on note on
when playing polyphonic note off turns off all notes
if you know how to fix these, please post here.
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
