i have a problem with "contact@sensomusic.com" to send you bug report.
i have an other problem with the module sampler, i use it with overdub record, when i use "clear list" and do an other recording session with overdub the last session reappear.
I use the pro2.81c version i haven't got the same problem with the pro2.64b
version.
headphoner
bug overdub
yes you are right, the mail contact@sensomusic.com doesn't work.
Fixed now.
I'll check the overdub bug.
thanks for feedbacks
Fixed now.
bug fixed, next release.
The "clear rec" button now works for overdub record.
Users browsing this forum: No registered users and 483 guests
