Conductor and Cycle
noise2sine
Unread post by noise2sine » 03 Apr 2013, 10:51
I'm using a lot the conductor and i was thinking if it would be possible if the scene of conductor could change automaticly according to a number of cycle (bars) ?
For example the conductor scene 0 is played 8 bars then it move to scene 1 for 2 bars and so on ?
That way it would be cool to play along with an istrument and having a structure playing .
joffo78
Unread post by joffo78 » 03 Apr 2013, 13:18
hello noise2sine.
Somthing like that could work :
joffo78
Unread post by joffo78 » 03 Apr 2013, 14:23
another example to tottaly answer at your question. http://www.sensomusic.com/forums/upload ... ductor.wkp
It's very more tricky but it does what you want.
noise2sine
Unread post by noise2sine » 04 Apr 2013, 09:20
Hello Joffo78,
Thanks a lot for your patch.Nevertheless i have few question :
- We can enter bars numbers in the list box right ? but i couldn't find the relation between the list box values and the different snap shot in the conductor ?
I didn't get for example how the snap 5 can go back to snap 1 ? and how i determine that the snap 5 is 5 bars long and the snap 1 one bar long ?
joffo78
Unread post by joffo78 » 04 Apr 2013, 09:59
in this way each line of the lst box corresponding to a snap.you can only go in chronologic mode.
But finally i found a better and simpler way to proceed : http://www.sensomusic.com/forums/upload ... sition.wkp
in this patch you've just to create a pattern list where each line is the bar position.the number is the snap number.
noise2sine
Unread post by noise2sine » 04 Apr 2013, 10:30
Thank you for the new version, i get it more :) . The patch is close to be perfect to me .... what i have done is : for example snap 1 is 4 bars long, so i have writen 4 times 1 in the list box .
Do you think it would be possible to have two list boxes like :
Snap numbers of bars
1 4
2 2
3 24
4 3
anyway i don't want to bother you more, if you don't have time for that .
Thanks a lot anyway
joffo78
Unread post by joffo78 » 04 Apr 2013, 10:56
What you propose is closer than the first version . The advantage of the second is that you can recall a snap in any step. for example :
snap 1 for 4 bars , snap 2 for 2 bar, snap 3 for 1 bar and return to snap 2 for 4 bars.
joffo78
Unread post by joffo78 » 04 Apr 2013, 10:58
if you be patient , i heard that with hollhock it vill be easy to do that with the grid mode. you will can change time signature to.
noise2sine
Unread post by noise2sine » 04 Apr 2013, 11:16
Yes you are right the second solution is better because more flexible . And you are right too about patience, but do you really think Hollyhock will be out one day ? (joke :) )
thanks again
joffo78
Unread post by joffo78 » 04 Apr 2013, 11:27
About hollyhock, i don't know when does it coming but i'm sure our patience will be rewarded ;-)
noise2sine
Unread post by noise2sine » 04 Apr 2013, 11:29
Perfect ! Really thank you !
noise2sine
Unread post by noise2sine » 09 Apr 2013, 14:01
Some times ago Nay Seven made this patch :
http://www.sensomusic.com/forums/upload ... change.pat
In this patch, while changing snap in the conductor, program change are sent too, very very usefull while using 4 hardware machine like me.
Your patch is perfect too .My wish is to have inside the same patch the one made by Nay Seven and yours :
http://www.sensomusic.com/forums/upload ... %201.1.pat
I didn't manage to make it work
If you have a clue ?
joffo78
Unread post by joffo78 » 10 Apr 2013, 14:36
Il ike this solution too :http://www.sensomusic.com/forums/upload ... needed.pat
With it you don't need to create snapshot to recall you PGM !
noise2sine
Unread post by noise2sine » 10 Apr 2013, 15:39
Thank you so much for the two patches ! They are working perfectly, and true, the second solution is better now.
Thanks again
Users browsing this forum: No registered users and 95 guests
