Hi
It's not the first time, I have need just click tempo to know the time of song or other things, but very quickly and simply !
I suggest to integrate a metronome (click) on dashboard and the patch metronome will be rest a patchvwith an local synchro for example and anything else
I hope my suggest is clear,
see you
alain,
Object Metronome all the time present on dashboard
Alain Vankenhove
yes clear!
good suggestion but more on the synchro panel than on the dashboard?
Alain Vankenhove
just a click button .... ?
Asus A7C dual core/RME Fireface UC/Axiom 25/MPD 24/Trumpet/BCR2000/FCB1010
LevraiBernardo
Yes, it would be great, even if it's quite easy to build. A good thing would be to choose the 'tic" sound and above all on wich audio output it will be played.
Users browsing this forum: No registered users and 68 guests
