Track count
you can explore with IML and the send messsage module ( or script)
and use strings like
LIST_CAPTIONS_ALL_TRACK
Thanks Nay. I'll give this a try.
Say, I saw your Vimeo video on a tactile interface for Aalto. Very cool! Is this workspace somthing you'd be willing to share?
Regards,
Scott
Scott
yes, no problems, I've several tools for Aalto
here a workspace ( from video) and 2 patches to randomize in a selective way and one with a BCR 2000 if you have one, they was done with V 1.2.6 ( you can have the 2 versions installed)
so if you have only the last 1.3 you have to adapt it, cause Randy have add some new inlets.
Download
have fun
Download
have fun
Thanks Nay! I'm looking forward to playing with this.
I've tried sending LIST_CAPTIONS_ALL_TRACK using the Internal Message module however I'm not sure where I would find the output of the command. Do I definitely need to write a script for this, or there a module that will output the track captions?
Regards,
Scott
Scott
yes, i suppose a script guru can help you on this ( maybe create a new explicit post) using a variable and send it to an output.
I'm not a script guru, but I succeeded!
Here it is: http://www.sensomusic.com/forums/upload ... cks.script
Thanks percuson. It works like a charm. Well done!
You have given me the courage to try scripting myself.
Regards,
Scott
Scott
Congrats percuson !
