hi there.
this software is very cool. thanks a lot.
question : how to disconnect modusl between them ?
shortcut key ?
how to disconnect modul
To disconnect wire, simply do the same operation than for connect.
...or select the wire by clicking the little square in the middel of it, and delete it like it was a module. A workaround if want to remove all connections to a module, is to cut'n'copy it (good ole' Ctrl-X, Ctrl-V
Users browsing this forum: No registered users and 384 guests
