Can Interface Builder do This?
erjos
Unread post by erjos » 24 Jan 2013, 18:21
Hello Guys,
I have the feeling that what im trying to do is very simple,but till now imposible for me to find searching.
I need to start Usine automatically in windows startup folder (pretty basic) and i need to start it each time in IB mode, at a certain workspace, full screen in my secondary display (win xp dual monitor configuration)
My patch is a simple big button touch screen friendly VSTi preset manager. nothing special.I need to have the setup as simple as possible because my KBD player dont like clicking too much with the mouse.In other words i need to emulate the way in which the normal comercial keyboards/workstations load. this way, the Keyboardist will just power on the pc and start switching between sounds.
Any help or idea is very much apresciated
Regards
Erjon Zaloshnja
In Sound We Trust
Unread post by nay-seven » 24 Jan 2013, 18:50
Here a patch for this, you'll need to create a midi learn on the + button of the IB mode , you can use any CC number of course
erjos
Unread post by erjos » 24 Jan 2013, 19:25
thanks Nay
i have seen this,but it occupies a precious midi button,and it does not resolve the problem of draging usine window to the next screen and maximizing it by double clicking (my secondary screen has a different resolution)
Isnt it any simple thing like a .ini or info,settings file we can edit,in order for usine to remember where it started the last time? It will allways start at the main monitor.
In Sound We Trust
Unread post by nay-seven » 24 Jan 2013, 19:45
ok, sorry, i read too quickly...
not sure but it's more on windows side ? can't help cause i don't have dual monitor installed right now, so i can't test
really strange Windows don't remember last position
erjos
Unread post by erjos » 24 Jan 2013, 21:31
Thanks Nay, Ultramon seems to be a somewhat solution.I will give it a try later and will give feedback.Thanks
In Sound We Trust
