Master Solo/Solo Defeat?
Unread post by bsork » 02 May 2007, 09:05
Would it be possible to add a Master Solo indicator/switch in the dashboard, preferably with a defeat all function? It would light up when one or more tracks are in solo mode, and if turned off all soloing would be cancelled.
A similar Master Mute could also be useful sometimes.
Vincent
Unread post by Vincent » 02 May 2007, 18:01
Hmmm, the dash will look like a star-ship's one! I like that! Let's do the trip!
Unread post by senso » 03 May 2007, 08:37
Yes, a solo indicator.
But I'm not sure the dashboard is a good place.
Let me think about it: create a small panel near the master in/out?
Unread post by bsork » 03 May 2007, 09:06
Well, I proposed the dashboard since there's a little space left under the midi/osc indicators, but alongside the master fader would also be ok.
An added "bonus" though with placing it in the dashboard, is that the button(s) would still be visible if one uses the interface builder for the patches and reduces the size of Usine's main window to show just the dashboard.
Unread post by senso » 03 May 2007, 16:58
Ok, I will see.
thanks for the feedback
