cc to note addon
damstraversaz
Unread post by damstraversaz » 26 Nov 2012, 19:44
Hi
I'm actually trying to create a cc to note patch. the main idea is to create a note on when the cc message is up to a certain value et to create a note off when the cc value is below the choosen value. I suppose that's not a really hard task, but I must admit I did not find a good solution for this. it could bevey useful for analog input of all the capture devices, as they just able to send a continous signal like cc.
If someone is interested, I have first in mind this sort or patch for usine beatfader
beatfader video
with the possibility to choose the limit between the cc value for each note, with note off send each time you pass a control point, or with a fixed length value . as you see, I'm very far from this actually
thanks a lot for reading my awful english
Damien
Unread post by nay-seven » 26 Nov 2012, 21:08
Not exactly what you're looking for but can be a start
Download
joffo78
Unread post by joffo78 » 27 Nov 2012, 00:42
Hello. You can try my solution. it could be a beguining too : playing with one fader ;)
r.erorr
Unread post by r.erorr » 27 Nov 2012, 03:06
Hi, Joffo78, before I manage your patch , can you leave some words about how the velocity works in your cease?
is it possible likewise measure mouse speed?
Unread post by nay-seven » 27 Nov 2012, 08:32
Cool one Joffo !
damstraversaz
Unread post by damstraversaz » 27 Nov 2012, 09:35
thanks to all, that's some really interesting patchs, I learn a lot !
here is a very litle version with just one note output, but you can send a note off message below the cc treshold instead using a fixed lenght.
cc to note converter onoff
