trig when pos meet marker
something like this..?
and also this . . .
http://www.sensomusic.com/forums/upload ... arkers.pat
r.eroor you solution is very clever but a little heavy (apply a polyphony each time the number of marker change...).
Nay with your solution it's impossible to change the number of markers isn't it ?
e.erorr i didn't notice but in this way it work only if the marker are read in the correct order. How can i do to have the number of the marker
active in all circonstances ? and i can't have the number of the marker.
anyway, i want to find a solution to have a trig each time a value correspond at one of the value contains in an array and the number position of this element.
Joffo78 what do you mean with "correct order"? Yes, it works only with "auto sort markers" option, that is 1,2,3,4,5,6 etc.
if you want random positions like 6,3,7,9,2,6,3,5 it will become more heavy.
Aaa . . you want to add markers at predefined order or sample position.
Nice, if this is solution
Not really a solution because it doesn't work yet.but perhaps
A beginning of a way ...
In fact the solution would be a script that make a caparassion of one value and all the values of an array.
After it could give us the value and the number off the element of this value
I can easiely imagine one float input for the value one for the array and one output for the index of the value witch correspond with the input
yes, maybe the difficulties is to have an efficient comparison between number with digits...?
Numbers that have some decimal ? 1,38 for example
Hi, joffo78, can i ask what we gain from adding and removing markers in realtime? because, if the markers positions are previously defined, I can't see essential difference between presence and absence. You can easy include or exclude markers from playback.
If you want visual feedback only from active markers maybe try to experiment with colors: SET_LAYOUT 'markers color' and 'markers font color' ?
Have a look on sergio slicer patch to understant the interest of it.
I think is very usefull to set marker to have a trigger point at one position of one sample (to automatize synchronised action for example)
I manage to do this with addons array difference : trig
It work to indicate when position meet marker (with round approximation) but it doesn't give me the marker number
hello
i managed to do that :
trig marker
i have 2 problems :
1 because the necessary round operation the trig is imprecise.
2 i found an empiric solution to detect the number of marker, it work except the last marker. Why ?
trig marker
i have 2 problems :
Users browsing this forum: No registered users and 29 guests
