Hi, is it possible to divide gesture detection script in several modules so we can create advanced gesture recognition?
single touch
mouse speed - much only if mause speed = ?
gesture length - much only if line lenght = ?
gesture durability - much only if gesture = ? sec. long
double touch
distance between two touch points - much only if distance between <> ?
lines crossed - much gesture only if two lines crossed X
advanced gestures
A good suggestion, don't know if if it's technically possible
waiting for this ,i suppose you can extract the gesture array and use counters for time based propositions and mouse X and Y position to calculate distances/cross..?
I imagine gesture modules as special arrays, that detect gestures from screen/container/control panel [like mouse], so we can receive gestures from any place of screen.
For those interested in one of the only projects pertaining to gestural learning and musical control that's anywhere's near where I think such things should have advanced to by this point in time, check out:
http://wekinator.cs.princeton.edu/
Useful info, thanks!runagate wrote:For those interested in one of the only projects pertaining to gestural learning and musical control that's anywhere's near where I think such things should have advanced to by this point in time, check out:
Users browsing this forum: No registered users and 75 guests
