input volume control
Ariajazz
Unread post by Ariajazz » 06 Sep 2012, 22:34
Hi. I need a way to control signal input. The idea is to swap between two input values ​​using a switch. The maximun value will be 100% of tne input and the other value 70% of the whole input. This is to control amp sim input signal. How can I do this using USINE tools?
tanabarbier
Unread post by tanabarbier » 07 Sep 2012, 00:13
You have a track input module (is it the right name?) that you can put anywhere, just specify wich track you want it to control, and then a input volume inlet, if I remember well. At this inlet you connect a switch with the two values (for on and off) that you want and that's it!
Ariajazz
Unread post by Ariajazz » 07 Sep 2012, 02:14
That's exactly what I did after thinking for awhile and before I read your reply .It worked perfectly. Thanks anyway. USINE is very intuitive
