midi foot switch
Ken29
Unread post by Ken29 » 04 Sep 2012, 21:23
Hi Guys,
I'm looking for a good (cheap and reliable) midi foot switch (on/off). Any idea ?
Thanks Mates
Kenan
multiphone
Unread post by multiphone » 04 Sep 2012, 23:40
Hello Kenan,
I Use the switch input of my BCF 2000 (If du you have one), only one switch but for me i'ts enough.
Best
HB
Lines / Points / Squares
http://www.hervebirolini.com/
damstraversaz
Unread post by damstraversaz » 05 Sep 2012, 10:16
I have this one. the quaility is very high, and you will have a expression pedal input.
umi3
GDLive
Unread post by GDLive » 05 Sep 2012, 15:52
I've a second hand FCB1010, which was cheap but do the job.
It is a little heavy, but with lot of switchs
Unread post by nay-seven » 05 Sep 2012, 17:19
And if you like DIY and practice a little soldering, an old usb joystick can also be a cheaper solution...;-)
gercha1
Unread post by gercha1 » 05 Sep 2012, 19:02
hi ,
the cheapest , a dance pad connecting in usb ,
I use 4 for live musicwith HID module ,[img]C:Documents and SettingsgéraldBureau2nd-dance-pad.jpg[/img]
10 switch in each mat I you want a patch, no problem
gercha
Unread post by nay-seven » 05 Sep 2012, 19:06
@gercha : you'll need to upload your picture before use it in your post, check here if needed
Ken29
Unread post by Ken29 » 05 Sep 2012, 20:32
Thanks for the answers guys !
Actually, it is for a single concert, the BCF 2000 is a great idea, I can easily have one lent for this concert.
Kenan
multiphone
Unread post by multiphone » 05 Sep 2012, 22:40
And if you want you can connect two guys on the BCF 2000 : Switch and expression pedal .
I Use a Korg EXP-2 as expression one.
http://www.thomann.de/fr/korg_exp2_expression_pedal.htm
Not very cheap but very efficient.
Best
HB
