Usine on Mac OS and RME sound card
Unread post by cmodica » 25 Aug 2012, 14:43
Hi all.
I plan to change my old laptop soon. I think i will buy a MacBook pro. But i work a lot with Usine ...
Could you tell me somethink about Usine on Mac OS ?
It will be ok in few weeks ? Mouth ? Long time ?
I have an RME Multiface but if i change my computer i should change my soundcard too because the PCi express card is not present in new laptop. :o
Did some one use the RME Fireface UCX in USB mode ? Is it work well ?
Unread post by nay-seven » 25 Aug 2012, 15:04
Can't answer for the RME, but for Usine, we hope to have some beta versions for you around the end of the year :)
Unread post by cmodica » 27 Aug 2012, 16:50
Ok. Thank you Nay.
Users browsing this forum: No registered users and 215 guests
