usine and sampletank - vsti loading problem
barabou
Unread post by barabou » 27 Jul 2012, 15:04
Hi Usiners,
I have trouble loading sampletank2 Vsti in usine 5.80 versions.
It still works well with former usine versions (5.70.) but no way to have it working in any 5.80 versions I tried.
Does someone else have this problem ? is there a way to fix it ?
thank you for help
Unread post by nay-seven » 27 Jul 2012, 15:41
Can give us more informations...?
the version you use and what's happen when you load the DLL..?
barabou
Unread post by barabou » 27 Jul 2012, 17:07
Hi nay,
I tried : usine pro 5.80.004 , easine 5.80.004 and usine free 5.80.013 (all stand alone) > all do not work.
i get a pop up message: problem loading sampletank2 Vst.
in the patch a vsti panel appears but all parameters appear as "not valid" (but connections midi in , audio in and out are there)
again, no problem when using usine pro or easine 5.70.
Unread post by nay-seven » 27 Jul 2012, 17:23
i was talking about the sampletank version, if it's the free one i can test, not for the others ones
and any chance there's difference in your test..? i mean same partition/vst dir and so..? i know ik products are really sensible about path/authorization
barabou
Unread post by barabou » 27 Jul 2012, 17:34
sorry, yes it s the free version. 2.5.5b
the vst dir (and so the dll) is exactly the same in all my usine configurations (also same asio config)
Unread post by nay-seven » 27 Jul 2012, 18:52
ok, so I've tested the free version, no particular problem here in the last pro 5.80.013 one, or older...all works fine
so i don't know how to help you
barabou
Unread post by barabou » 27 Jul 2012, 19:26
well thank you. i will just try to reinstall the all thing again and hope to be more lucky this time
Users browsing this forum: No registered users and 318 guests
