Hi everybody!
I just ran into this page : http://www.spaceraiders.co.uk/sick.html where you can download a LOT of small VSTs, intended to be used in an modular environment. They are synthesis oriented (generators, filters, envelopes, mixers, etc), all made with synthedit and they sound really nice! The only problem I'm having is with the oscilator, it only has audio inputs, no data input, and I can't find a way to make it work...
Spacedad's VSTIs are worth trying too.
I was specialy thinking of cleverconqueso's idea of a modular synth with usine, that wouldn't be all native but if it sounds good that's good!
New VSTs for modular environment
tanabarbier
yes, I've tested spacedad modules a while ago , connections use audio outputs , here an example :
tanabarbier
And how come you ALLWAYS have a solution to everything?
Thank you!
Thank you!
Users browsing this forum: No registered users and 647 guests
