two active lines same track
Ariajazz
Unread post by Ariajazz » 20 Jun 2012, 02:16
Is it possible two have two or more active lines in the same track? If yes how can this be done?
Thank you
Unread post by nay-seven » 20 Jun 2012, 08:33
you can use a new track with buses to activate your line in inserting a patch on/off module in your patch :
you can also use directly the on buttons ( all or rack mode ) on the patch or create a key or midi learn on it too
Users browsing this forum: Bing [Bot] and 280 guests
