Hi
I try to change the speed of how fast play button is triggered. most simple way, there is local sync 16 led conected to play button. When I change the tempo of local sync module the play button is triggered faster or slower according to tempo. Yes, but there is delay when I change the tempo fader and it is not possible to make smooth increase/decrease of triggered speed. fore example if slider is on 60 there is one speed, and if I slide it up to 300 I got another speed, but only after delay. But I what that trigger speed can be detected faster according to slider so to make play speed increase or decrease faster and smother.
is it possible some how filtering milliseconds with math or... ?
increase/decrease trigger speed without delay
have you tried the sub patch clock ( in modules/synchro & time) ?
and remember the speed depends also of your block size
Clock doesn't help, because there are to much ticks while changing ms slider. Actually I got noise.
But, yes block size was useful info. thanks
