I've tried the chromatic tuner, but it seems it doesn't work properly. The note A is ok, but a D3 for example is about 10cents below the good tuning (I've checked with two other tuners). Is it the same for you ?
Chromatic tuner issue
just checked with an acoustic guitar , here I've a -4 cents difference with the VST C_tuner for a D3, more or less difference depending of the notes. do you test with hardware tuner or VST ones..?
La Tenaille
Hi Nay
I compared with 2 hardware tuners. If I fine tune the whole strings of my cittern with the Usine module the result is quite ugly...
yes, i confirm, this patch can't compete with hardware tuner, not enough precise..maybe will be update one day
Users browsing this forum: No registered users and 296 guests
