I got a problem in FL Studio with usine vst. (when using it as a effect)
I cant map any of usine knobs or switches.
I can see in usine that im getting MIDI signal, but for some reason i can only map one control..its very strange.
Its a very simple setup, ch1, cc 1,2,3...
I have tried with "Midi CC Knob" but with no luck.
Every other plugin works great when using MIDI OUT in FL Studio.
I have latest version of usine vst and FL Studio.
Can some one help me?
Thanks!
Problem in FL Studio
OK it works with usine pro vst 5.80.006 but not with the latest version, bug?
There is a problem with 5.80.006, i can only put 5-6 usine vst with my setup
then everything is crashing every time in Ableton Live and FL Studio. Im getting message "External exception C0FB007F"
With version 5.80.12 i can load more than 10 usine vst (same setup) with no problems except MIDI OUT in FL Studio.
will try to reproduce this with FL demo, what OS do you use..?
