Loading sample in the Macro-micro montage patch
noise2sine
Unread post by noise2sine » 15 May 2012, 14:25
How can i load different samples in the different players ? I can delete the ones already loaded but it's impossible to load new ones.
i have tried "add file" from the list or drag and drop.
Thank You
Unread post by nay-seven » 15 May 2012, 14:43
If we talk about the same version ( multiphone one based on tanabarbier one) drag & drop works here, but be sure to have 8 grains selected ( each grain correspond to a sampler here)
noise2sine
Unread post by noise2sine » 16 May 2012, 13:59
Still can't make it ! if i drag and drop an audio file to a sampler Usine ask me if i need a wave player for reading the file...
can't load anything even with 8 grains selected
multiphone
Unread post by multiphone » 16 May 2012, 14:06
Hello Noise2sine,
Can you give me a link to the patch ?
Best
HB
Lines / Points / Squares
http://www.hervebirolini.com/
noise2sine
Unread post by noise2sine » 16 May 2012, 14:20
Hello Multiphone,
the patch is in the uploader section ( don't know yet how to make a link)
Unread post by nay-seven » 16 May 2012, 14:27
works correctly here
Are you sure you drag & drop from the Usine browser on the wave display modules..?
noise2sine
Unread post by noise2sine » 16 May 2012, 14:28
no , i was draging from windows explorer !
Working fine now !
Thanks a lot for your attention
Users browsing this forum: Google [Bot] and 25 guests
