Hi everybody.
I posted a new addon in synchro/time part.
This is named time fader time fader
It allow to set a time to recall an intensity smoothy.
Don't hesitate to try it and send me our suggestions to improve it.
JOF
time fader
this is a cool one, a very cool one! as 1 of my main goals is to get smooth transitions between sounds and i was working with conductor on this which gave some little problems, like the patch turning on or off in the middle of the time=hard switch ...
still i am to stupid to figure out how to set values :rolleyes:
maybe a little text file in a zip to discribe the patch?
idea: sync to bar/beat/cycle?
ah, think i got it:
enter "time in"
set fader value
select slot and store
ah, think i got it:
enter "time in"
set fader value
thinkpad t61, xp 32bit, 2gig ram, rme multiface // acer timelinex 3820t, win7 64bit, 4gig ram, NI komplete audio 6 // reaktor, battery, nuendo // roland hpd15
cool job joffo !
but yes maybe some little explanation about pause/cut ..?
some suggestions
maybe a knob to set the time in ( faster than double click)?
the pause switch must be set as "not saved in preset " and , " not saved in conductor"..?
separate the fader part from the presets manager in a sub-patch to easily add more faders for newbies..?
btw, you have a sub patch "256preset" which is not used
some suggestions
Users browsing this forum: No registered users and 109 guests
