vst vs. vst-i?
mat
Unread post by mat » 04 May 2012, 07:25
can someone explain me the technical difference between vst and vst-i?
vst can have audio in. vst-i not. is it that? processor load?
cant i just use vst for effects and instruments and forget vst-i?
thinkpad t61, xp 32bit, 2gig ram, rme multiface // acer timelinex 3820t, win7 64bit, 4gig ram, NI komplete audio 6 // reaktor, battery, nuendo // roland hpd15
Clearscreen
Unread post by Clearscreen » 04 May 2012, 08:23
Some vst hosts will only load a vsti as the first thing on a midi track - for example ableton live. Otherwise I don't think there's any difference in performance?
Unread post by nay-seven » 04 May 2012, 08:27
You're right clearscreen, the differences are quite subtle and more technical. And you can load an effect in the VSTi version and an instrument in the VST one. It's really depends of your Host .
mat
Unread post by mat » 04 May 2012, 15:28
i see.
thanks!
