MIDI auto harmony
r.erorr
Unread post by r.erorr » 03 May 2012, 05:23
Hi, auto harmony script is can add 4 voices. I don't know much about notes, but is it possible to change this script and add more than 4 voices, for example 5,6,7,8 ? is there some kind of law that determine those harmonies? if so maybe it is possible to add more voices, or not?
iococoi
Unread post by iococoi » 03 May 2012, 08:33
hey there..
well, it's all in the script. changing the harmonies isn't that great of a deal..
voices might be, depending on your coding skills.
~ io
r.erorr
Unread post by r.erorr » 03 May 2012, 15:01
Yes I tried to add more voices and harmonies, but it's not so easy. I can't compile the script because something is wrong before main process.
r.erorr
Unread post by r.erorr » 03 May 2012, 15:11
And one more thing... the one note or pitch consist of several sound waves or frequencies that are conditionally harmonic. And this script make something like chords , yes? [or make harmony from another 4 harmonies]
- is it possible to make more complex harmony from those chords?
tanabarbier
Unread post by tanabarbier » 03 May 2012, 19:11
It's not answering your question but this patch I made is a 32 bars chord sequence player, so maybe you could use the "chord calculation" part (those are chords, not scales, but that's a start). I remember that I started trying with this script and then gave up and patched it with a lot a cables instead of a few code lines (that I don't know the first thing about).
Here it is :Download
the main purpose of it was to make a play along type of thing for a jazz playing friend.
Unread post by nay-seven » 03 May 2012, 19:24
@tanabarbier : i've edit your link for the patch ,it was not working ;)
tanabarbier
Unread post by tanabarbier » 03 May 2012, 19:31
Aaaah thank you! You always save me from my web-incapacity !
r.erorr
Unread post by r.erorr » 04 May 2012, 02:31
thanks for opinion, I will try it out
Users browsing this forum: No registered users and 52 guests
