expanding a patch problem
seamus
Unread post by seamus » 22 Apr 2012, 06:21
im having a problem when i try to expand a patch. It used to work fine and now when i click on the neon button in the top left corner it doent expand properly.
i have to clear and reload the patch for it to work properly again. Then after some time it happens again.
It happens in both grid and interface mode
r.erorr
Unread post by r.erorr » 22 Apr 2012, 06:57
you can put all your layout items in container and then minimize. maybe it helps ... ?
seamus
Unread post by seamus » 22 Apr 2012, 10:42
all the elements within the patch all go in one container?
Unread post by SylvainT » 22 Apr 2012, 12:53
I found this problems time to time
Don't know why, no reason, very rare
But when it appear, the lonely way was to copy/past all the stuff in the workspace and reorganize everything
seamus
Unread post by seamus » 22 Apr 2012, 15:56
I tried building a new workspace with the problem patches and it still happens
I think it is because my patches are a big patchwork of too many things?
Maybe I can upload them here and someone can tell me if something is wrong?
Unread post by nay-seven » 22 Apr 2012, 16:00
Yes, it's a curious bug , not easy to reproduce
generally , as said e.error, putting all your elements in a container can solve the problem
seamus
Unread post by seamus » 24 Apr 2012, 09:10
It's all about containers then.
http://www.sensomusic.com/wiki/doku.php ... _container
this page is blank when I try to go to it.
seamus
Unread post by seamus » 24 Apr 2012, 09:21
rotator patc hfor wind controller
here is a patch that im not sure is set up right container wise. Im having problem with this patch with the same above problem
seamus
Unread post by seamus » 24 Apr 2012, 09:22
damn sorry about the title of it above. tired i guess.
Unread post by nay-seven » 24 Apr 2012, 11:57
yes, the wiki page is a part of the "to do list" sorry for that
you can check this one in a first time:container
i have change your patch : download
you can be easily lost in container, parent container, in your patch a container in a sub-sub patch was in standalone mode.
so I've extract the sub patch and set the container as control panel, must work and avoid issues
seamus
Unread post by seamus » 24 Apr 2012, 21:45
I can't find which element was in standalone mode.
It would be very helpful to see the problem. Thanks for your help!
seamus
Unread post by seamus » 24 Apr 2012, 21:52
I think I see it now thanks!
Unread post by nay-seven » 24 Apr 2012, 21:53
It was the container module in the presets patch ( who was itself in a sub-patch )
Unread post by nay-seven » 24 Apr 2012, 21:55
crossed posts !
cool!
seamus
Unread post by seamus » 08 May 2012, 21:51
i still dont totally understand how to use containers. It would be helpful if the FAQ had some info on this.
Unread post by nay-seven » 08 May 2012, 22:15
ok, gone to add a wiki page and good news , this bug have been resolved by senso for next release ;-)
Users browsing this forum: No registered users and 69 guests
