Sorry for the re-posting, but my title must've not been very attractive. lol.
Hey, all.
I've incorporated a harmonizer in my synth player's patch using the Auto Harmony II script, editing the script so that it only plays a major/minor 3rd. I've noticed that it misses some of the harmonized notes, especially if I'm playing quickly, or with polyphony. I have tried using a separate dispatcher(since I also use a split with multiple vsts) and duplicate Vst, thinking that the vst was receiving on/off message overlap. this has helped the problem a bit, but it still isn't perfect. was wondering if anyone has any advice about getting perfect tracking, even with polyphony, or if someone could recomend a good script/vst (free) to accomplish midi harmonies. THANK YOU!!!
Problem with auto-harmony script
maybe you can share the script you modify so a guru script can check..?
btw I've also answer on your first question about pitchbend/vibrato
Users browsing this forum: Bing [Bot] and 17 guests
