Feedback Loops
caco
Unread post by caco » 04 Apr 2012, 22:46
Hello, I have been playing around with feedback loops and I am presuming that there is a latency equal to one BLOC on all feedbacks, is this correct?
I was trying to create a lowpass iir using modules so I need a one sample delay to pass the filter's output back to its input. Am I correct that this is not currently possible? I would need a BLOC size of 1 or to do it all in script or the SDK?
Unread post by nay-seven » 05 Apr 2012, 19:53
yes, i suppose you'll need a script or to create a user module again... ;-)
waolelaid
Unread post by waolelaid » 06 Apr 2012, 05:09
hello just a little question what does represent "a one sample delay " in duration or in length
is it less than 1ms ?
thanx in advance it's just for my little knowledge ;)
Friedrich Nietzsche
joffo78
Unread post by joffo78 » 06 Apr 2012, 13:04
hello
with a samplerate on 44,1khz you have 44100 samples per seconds.
so 1 sample equal 1000/44100= 0.027 ms ;)
waolelaid
Unread post by waolelaid » 06 Apr 2012, 16:43
hello joffo i made this operation but i wasn't sure of the result
thanx to confirm ;)
Friedrich Nietzsche
