Wii control possibilities
r.erorr
Unread post by r.erorr » 25 Mar 2012, 20:55
I don't know how to name the difference between mouse ant joystick, but I try describe...
joystick have XY controls, but it's not like mouse have XY, because actually joystick have only 4+1 buttons. With help of increment/decrement It is possible to control XY pad, but this is not so fast and smooth as with mouse. I don't have wii jet, but it looks that moust of wii XYZ outputs on module is like joystick have XYZ except "wii pos XYZ". Does it mean that it is posible to control YX pad with wii like mouse?
And what exactly I need to buy, if I whant to use all parameters on wii module? do I need some Bluetooth/IRD adapter or something alse?
Unread post by nay-seven » 25 Mar 2012, 21:50
yes, wiimote is smoother than joystick cause there's no central point , the other difference is joystick has physical limits so you need more calibration with wii
about what you need:
a wiimote
a nunchunck if needed
a bluetooth key+ bluetooth manager (type bluesoleil or native windows drivers)
r.erorr
Unread post by r.erorr » 26 Mar 2012, 03:32
ok, thanks for info...
