Changing vst presets
tpresto
Unread post by tpresto » 25 Mar 2012, 14:20
I would like to allow my synth player to change VST presets on the fly. How can I, for instance, use an external midi controller to send a command to change a vst's current preset (let's say a bass sound) to another preset (for instance, a synth lead). also, I'd need to be able to change vst banks, as well.
Todd
Unread post by nay-seven » 25 Mar 2012, 14:55
depending of your VST, some accept classic midi message, some not ( specially for bank change)
here 2 methods :
Download
tpresto
Unread post by tpresto » 25 Mar 2012, 15:03
Thanks, Nay7. I'm currently working and unable to try them out. I know this would be asking a lot, but could you send me a pic of the .pat in action?
Unread post by nay-seven » 25 Mar 2012, 15:13
here it is:
create midi module are set to control change
tpresto
Unread post by tpresto » 25 Mar 2012, 15:22
AWESOME!!! Thank you!!!!!!
tpresto
Unread post by tpresto » 26 Mar 2012, 16:01
OK, so I still haven't tried these options out yet, but looking at the picture, it seems that I'd only be able to switch presets in the n ± 1, linear fashion. so, my question is how could I change presets from, for example, a bass set at preset position 1 to a saxophone set to preset position 30?
Unread post by nay-seven » 26 Mar 2012, 16:12
i've a solution with the key numpad but with midi controller, not the same
Or will need 2 actions : one fader or increment button to choice then a second action to valid..is it possible for you ?
Unread post by nay-seven » 26 Mar 2012, 17:07
of course if you have a fixed list, you can use a simple combobox and edit it this way:
preset1=12
preset2=30
preset3=45
preset4=60
