hello
these are my first steps with Usine, after reading most of the manual. I'm trying to have Battery playing a sequence I program on the piano roll. It is very simple, I just started with a kick playing on the beat. Here is a screenshot (big image) :
http://img401.imageshack.us/img401/69/screenshohd7.jpg
What is happening is that the first three steps of the cycle are doubleplayed, (2 hits at the same time, with a tiny delay of several ms).
and I really don't understand why... Any idea ? Is there something unclean with the midi management ?
thx in advance !
Piano Roll acting strange
Il Sorpasso
- New member
great it seems to be exactly my problem
merci Vincent !
merci Vincent !
All post can be useful.
After you post I've decided to check the pianoRoll deeper. Result, the actual version is not so clean...
I'll post a new update (2.81c) which correct a couple of small bugs.
Users browsing this forum: Google Adsense [Bot] and 194 guests
