New Add-Ons Uploaded : one Polyrhythm Sequencer and a funny Delay
Hello Usiners,
So, two new Add-Ons uploaded
The Polyrhythm Sequencer :
This workspace is a rhythm sequencer, based on Nay-Seven and r.erorr ideas. At the beginning, that was a task to experiment array modules, matrix modules, polyphonic patches... The result look very interesting, so I want to share it with you. This workspace allows you to experience all this polyrhythms and all the polyspeeds you imagine.
Explanations are in the worspace.
All that stuff is pretty expensive in CPU, I really don't know why. So, any suggestions for involving this workspace are really welcome.
The Delays :
Delays based on joffodubdelay, with new controls, more feedback, new panner possibilities, FX send added
one is for stereo use, one is for quadriphonic use
you can find inside the patch a script that allows you to fill an array with a log, exp, cos, linear curve. That was the reason of that work
someone could be interested
Thanks for feedback
The Delays :
Thanks for feedback
huge work slydeparis ! ( and they say I'm crazy...
Really cool to add polyrhythms,now as you say it's really expensive in CPU
will take a moment to explore this monster,
maybe try to built a lite version..?
only 4 track, no effect, less buses, more on/off modules use and so..?
an interesting way to work is also to try to optimize a 1 track patch and duplicate in a second time...
hi nay. I'm very proud that you use my work to elaborate one addon
I will try this.
ciao
I will try this.
ciao
mm, maybe a little misunderstood here..?
it's Slydeparis who built this one ...
Thanks Nay
Remember that basics of this sequencer are you're ideas
When you mute one track, it's a patch on/off, so the track doesn't use any CPU more, in the sequencer and in the sampler (cause patch on/off works in poly).
I agree with a lite version, but I want to understand why it is so expensive in CPU. It's just a 8 tracks sequencer with some small FX.
Is it because Usine is very expensive in CPU? Maybe it's the price to pay for good sound?
Regards
Regards
mmm OT: sorry for question but SlydeParis are you the singer of Danforth? (who is also called sly, and sylvain, and from paris but i suppose you are few..:p)
Hello 23fx23
No, Im not a singer, I'm a sound engineer
well done sylvain. I love the sound!
multiphone
Hello Sylvain,
I like the sound too, congrat.
Best
Best
Thanks Olivier and Hervé for feedback
Did you have time to look at this workspace more deeply to explain me about heavy processing?
All te best
All te best
noise2sine
Really great job, but really heavy !!! Is there any chance to have a lighter version ? it would be wonderful !
I didn't look at this workspace since months, but thinking of it those days. I have some ideas to make it lighter, with possibility to choose from 4 to 8 tracks.
In fact, I thing that this kind of workspace are not usefull for live applications
But for making grooves at home it could be good
Regards
Regards
