typing a number instead of using fader/knob
La Tenaille
Unread post by La Tenaille » 26 Feb 2012, 22:32
Certainly not essential, but is there a way to type a value without using fader or knob?
I know I can triple clic a fader or a knob (with the mouse cursor moving on the first clic) but perhaps I miss a more suitable (natural) way ?
Unread post by nay-seven » 26 Feb 2012, 23:02
not a light solution and works only if you need only one fader but you use your numpad .?
download
La Tenaille
Unread post by La Tenaille » 26 Feb 2012, 23:27
wow, clever patch, and you're right, it's not light :D
I thought there should exist something like the text field module, but sending numbers instead of texts.
Forget it, I was just trying to gain some confort.
Thanks again Nay ;)
Unread post by nay-seven » 27 Feb 2012, 07:24
you can do simpler but always need 2 clicks :) :
CleverConQueso
Unread post by CleverConQueso » 27 Feb 2012, 20:17
I like to use the inc/dec feature on the faders. I put an up button and a down button then key-map the buttons to keys on the keyboard. It beats reaching for the mouse when you're concentrating on something else.
CCQ
La Tenaille
Unread post by La Tenaille » 27 Feb 2012, 21:17
Nice Nay, I didn't know string to float and it does the job nicely without heating my CPU :) Is the pass if change essential when connected to a delay pin delay module ?
CCQ > I use it to change tempo for now, in that case the increase decrease is not quick enough, and gives strange results ;)
Unread post by nay-seven » 27 Feb 2012, 21:51
no, the pass if change module was here for the fader, this way you can use also the fader to modify the value, without him the string to float is the master.
about increase/decrease tempo you can use the shift function of your keyboard : Download
La Tenaille
Unread post by La Tenaille » 27 Feb 2012, 23:16
The keyboard module is a nice feature :)
