WAV PLAYER PROBLEM
Ariajazz
Unread post by Ariajazz » 05 Feb 2012, 02:49
I'm pretty new to USINE. I'm loading wav files into USINE's Wav player that I need to be played JUST ONE TIME and not as a LOOP. I don't see any option in the MODE drop down box from the player. Is there any way to do that??? Your help will be highly appreciated.
Thanks in advanced
CleverConQueso
Unread post by CleverConQueso » 05 Feb 2012, 03:52
Check the 'sync'hro value in the sampler. Choose 'MIDI In' (connect a midi input and press a key on your keyboard if you have one) or 'Play Button' and press play or connect a button to the 'play' input.
Welcome.
-CCQ-
Users browsing this forum: No registered users and 53 guests
