Reaper ReaSurround
gthibert
Unread post by gthibert » 31 Jan 2012, 07:16
I don't know if anyone tried it, but the ReaSurround plugin that is coming with Reaper 4 is extremly powerful. The only problem is that it's a standard VST and I can't use it in Usine. I would like to use it from for live performances, but I can't figure out what would be the best approach.
I "simply" want to control all parameters of ReaSurround from a Usine patch while I feed sound from Usine to ReaSurround and then back to Usine. Maybe the simpliest thing should be to run Usine as a VST from Reaper, but I would prefer to run Usine as the host...
Guillaume Thibert
www.cemproduction.com
Unread post by nay-seven » 31 Jan 2012, 11:46
have you check the surround pack addon by Multiphone, can be a good alternative..?
multiphone
Unread post by multiphone » 31 Jan 2012, 12:36
Hello gthibert,
Indeed, the "surround pack" is the solution for spatialisation in usine, but, for the moment, elevation ( Z parameter : the height) is not include in this pack. Only the Reasurround and Acousmodules from Jean-Marc Duchenne http://acousmodules.free.fr/ are ready and available for free (Most of them...) for that.
i dont enderstand why you want to use Reaper as host ? Usine is completly multichanel Ready, until 32 channels.
HB
Lines / Points / Squares
http://www.hervebirolini.com/
caco
Unread post by caco » 31 Jan 2012, 13:32
And of course you can use Csound's Panning and Spatialization opcodes in Usine too :)
http://www.csounds.com/manual/html/SigmodPanspatl.html
Otherwise, if you want to route audio from Usine to Reaper without using the VST then you try JACK, Virtual Audio Cable or ReaRoute although you can expect latency doing it this way. Easiest to either do it all in Usine or use the Usine VST in Reaper.
multiphone
Unread post by multiphone » 31 Jan 2012, 13:47
Mmmmm,
As the very famous sentence of Senso : "Let me think about that" :D
I never Try this Csounds spat, nice collection,
But they have been programmed in 2000 !!! so...
HB
Users browsing this forum: No registered users and 62 guests
