waolelaid
Unread post by waolelaid » 14 Jan 2012, 15:54
hello usiners , i'm trying to use a 5.1system
but i don't find informations on the distance
between the front and the rear speakers
i know that the front and the rear speakers
must be at the same distance between left and right
but must they be at the same distance as if they were in
a square room ?
ex : if there are 2,5 meters between left and right
must i have also 2,5 meters between front and rear ?
to have a good effect
thanx in advance :D
Friedrich Nietzsche
Unread post by nay-seven » 14 Jan 2012, 16:50
definitively not a specialist but will not be easy to help you, cause i suppose many parameters count here,
the size and materials of the room, power of your system and so
here a generic French website, maybe you can find some infos
http://www.guide-du-home-cinema.com/schema_configuration_home_cinema/schema_configuration_home_cinema
waolelaid
Unread post by waolelaid » 14 Jan 2012, 22:47
hello Nay , you just found what i need
trying to have a square room seems to be
the best and there is also the height of the speakers
now i can fit out
well thanx Nay and good evening ;)
Friedrich Nietzsche
Ken29
Unread post by Ken29 » 15 Jan 2012, 11:05
Here's a real serious document for 5.1 installation : http://www.dolby.com/uploadedFiles/zz-_ ... Mixing.pdf
Kenan
waolelaid
Unread post by waolelaid » 15 Jan 2012, 17:40
Hi thanx Ken , seems to be real professional
gonna read this attentively :D
good evening
Friedrich Nietzsche
Users browsing this forum: No registered users and 167 guests
