latest version crash on exit
lxegs
Unread post by lxegs » 12 Jan 2012, 20:12
I have just downloaded the last 5.80 beta version and it works well but crashes on exit ("stackhash")
i have deleted all preferences but :
when i set "no sound device" --> no problem
when i choose the asio driver (i have a focusrite saffire 6 usb) it crashes on exit
so i think the problem is related to asio device
i have recently reinstalled all my computer under windows 7 x64
i haven't keep the last 5.70.035 version to test
should it be possible to download once more this version to test and check more details ?
i'm french user :)
clement
lxegs
Unread post by lxegs » 12 Jan 2012, 20:27
error log from windows says :
Faulting application name: Usine.exe, version: 1.0.0.0, time stamp: 0x4f0c78ff
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc000041d
Fault offset: 0x73064f0d
Faulting process id: 0xa84
Faulting application start time: 0x01ccd15f8e37b37a
Faulting application path: C:Program Files (x86)Sensomusic UsineUsine.exe
Faulting module path: unknown
Report Id: dbdce2bc-3d52-11e1-bc5b-1c6f65384661
I use other daws, Ableton live & renoise without problems
i had on the past same problems with no particular versions of usine
Unread post by nay-seven » 12 Jan 2012, 21:26
The windows message don't give any information, did this happen with an empty workspace..?
have you test with ASIO4all ..?
and how did you resolve this in the past ..?
lxegs
Unread post by lxegs » 12 Jan 2012, 21:59
yes it happens on the default workspace or an empty one
in the past, my system was also unstable with an older sound card referenced in the registry
can i download the version 5.70.035 ?, i m sure it worked well but i have installed some software since last time i used on my clean system
maybe it's one of them which makes that
Unread post by nay-seven » 12 Jan 2012, 22:28
Actually no, cause each download is individual
send a mail to contact@sensomusic.org, i 'll see tomorrow with senso if we can send you the demo version to be sure, waiting for this, try to investigate about your drivers and software installation.
lxegs
Unread post by lxegs » 12 Jan 2012, 22:50
i m a gold member so where's the problem to have that stable full version ?
lxegs
Unread post by lxegs » 12 Jan 2012, 23:02
very strange ...
i have tried with the stage version of 5.70.035 and no problems on exit
but when i try the 5.80.004 pro version, it exit one time correctly and the second one it crashes
usine logs says
[22:59:54] Usine Pro 5.80.004
[22:59:54] Initialization UDP SOCKETS
[22:59:54] Initialization UDP SOCKETS OK
[22:59:54] Initialization SCRIPT FORM
[22:59:54] Initialization PERFORMANCE CPT
[22:59:54] Create BitMapTmp
[22:59:54] Create CriticalSections
[22:59:54] Init Colorset
[22:59:54] InitLoadData :C:Program Files (x86)Sensomusic UsineDefault-settings.ini
[22:59:54] InitLoadData :C:Program Files (x86)Sensomusic UsineResourcesColorsColorSet.ini
[22:59:54] Init CpuUsage
[22:59:54] Init vertical font
[22:59:54] Init ASIOconvert
[22:59:54] Init Sockets
[22:59:54] Init MSGCMP
[22:59:54] Init MIDIcons
[22:59:54] InitLoadData :C:Program Files (x86)Sensomusic UsineResourcesLanglanguages.ini
[22:59:54] Translator form Created
[22:59:54] Hint form Created
[22:59:54] Test language done
[22:59:54] InitSaveDataApppend :C:Program Files (x86)Sensomusic UsineDefault-settings.ini
[22:59:54] FinalSaveData :
[22:59:54] Test ASIO error done
[22:59:54] Patch Form created
[22:59:54] Progress Form created
[22:59:54] Create GhostPanel
[22:59:54] GhostPanel RegisterTouchWindow
[22:59:54] InitLoadData :C:Program Files (x86)Sensomusic UsineWorkspace.wkp
[22:59:54] MainForm Form created
[22:59:54] Seq Form created
[22:59:54] Conductor Form created
[22:59:54] Conductor Lite Form created
[22:59:54] Start create Midi tmp
[22:59:54] Create Midi tmp ok
[22:59:54] start create setup controls
[22:59:54] Create setup controls ok
[22:59:54] Start create Midi devices
[22:59:54] Start Get MIDIin devices
[22:59:54] Get MIDIin devices done
[22:59:54] Num MIDIin devices = 2
[22:59:54] Create MIDIin device LPK25
[22:59:54] Create MIDIin device 2- Saffire 6USB
[22:59:54] MIDIin device created
[22:59:54] Num MIDIout devices = 3
[22:59:54] Create MIDIout device
[22:59:54] Create MIDIout device Microsoft GS Wavetable Synth
[22:59:54] Create MIDIout device 2- Saffire 6USB
[22:59:54] MIDIout device created
[22:59:54] Start Get MIDIout devices
[22:59:54] Get MIDIout devices done
[22:59:54] Create Midi devices ok
[22:59:54] Start create virtual in/out
[22:59:54] Create virtual in/out ok
[22:59:54] List asio driver proc start
[22:59:54] Query register asio list start
[22:59:54] Query register asio list ok
[22:59:54] Asio Drivers Count 1
[22:59:54] Get Dll path of Focusrite USB ASIO Driver
[22:59:54] findDrvPath start
[22:59:54] DLL path c:program filesfocusriteusb audio driverffusbasio.dll
[22:59:54] findDrvPath done
[22:59:54] Get Dll path Success
[22:59:54] ListAsioDrivers Proc done
[22:59:54] List asio driver proc ok
[22:59:54] Setup Form created
[22:59:54] Help Form created
[22:59:54] Start Create Browser Modules
[22:59:54] Set treeview root1 C:Program Files (x86)Sensomusic UsineModules
[22:59:54] Set treeview root1 ok
[22:59:54] BrowserModules created
[22:59:54] Start Create Browser Patchs
[22:59:54] Set treeview root1 C:Program Files (x86)Sensomusic UsineDemo
[22:59:54] Browser Patchs created
[22:59:54] Start Create Browser UsineLib
[22:59:54] Set treeview root1 C:Program Files (x86)Sensomusic UsineUsine Library
[22:59:54] Browser Usinelib created
[22:59:54] Start Create Browser vst
[22:59:54] Set treeview root1 C:PluginsVST2 32b
[22:59:54] Browser vst created
[22:59:54] Start Create Browser sound
[22:59:54] Set treeview root1 C:Program Files (x86)Sensomusic UsineDemoAudio
[22:59:54] Browser sound created
[22:59:54] Start Create Browser addons
[22:59:54] Browser addons created
[22:59:54] Browser Form created
[22:59:55] Lan Capture Form created
[22:59:55] Colors Form created
[22:59:55] InitLoadData :C:Program Files (x86)Sensomusic UsineDefault-WavePlayer.waveplayer
[22:59:55] BrowserJuke.LoadData WaveCollect.clearNoPrompt
[22:59:55] WaveFileCollection.Clearwaves
[22:59:55] WaveFileCollection.Clearwaves OK
[22:59:55] BrowserJuke.LoadData WaveCollect.LoadData
[22:59:55] LoadFilePeaks:C:Program Files (x86)Sensomusic UsineDemoAudiozdjam.usine.peak
[22:59:55] BrowserJuke.LoadData inherited LoadData
[22:59:55] BrowserJuke.LoadData OK
[22:59:55] Juke Form created
[22:59:55] Patch Remote Form created
[22:59:55] List Form created
[22:59:55] About Form created
[22:59:55] InitLoadData :C:Program Files (x86)Sensomusic UsineDefault-settings.ini
[22:59:55] Record Form created
[22:59:55] InitLoadData :C:Program Files (x86)Sensomusic UsineDefault-Remote.remote
[22:59:55] Remote Form created
[22:59:55] Set Vst param dlg created
[22:59:55] Glob ListBox Created
[22:59:55] Layout form Created
[22:59:55] Begin MainForm Startloading
[22:59:55] Set treeview root2
[22:59:55] Set treeview root2 ok
[22:59:55] Sound card buffer size :0
[22:59:55] Bloc size :128
[22:59:55] MultiThread 7 threads.
[22:59:55] Set treeview root1 C:Program Files (x86)Sensomusic UsineDemo
[22:59:55] Set treeview root1 ok
[22:59:55] Set treeview root1 C:Program Files (x86)Sensomusic UsineDemoVst
[22:59:55] Create asio driver proc start
[22:59:55] Get driver name proc start
[22:59:55] Get driver name proc ok : Focusrite USB ASIO Driver
[22:59:55] Get driver version proc start
[22:59:55] Get driver version proc ok : 00001
[22:59:55] Get num channels proc start
[22:59:55] Get num channels proc ok
[22:59:55] num input : 2
[22:59:55] num output : 4
[22:59:55] Get buffer size proc start
[22:59:55] Get buffer size proc ok : 136
[22:59:55] in latencie:330
[22:59:55] out latencie:466
[22:59:55] Get output channel info proc start
[22:59:55] Get output channel info proc ok
[22:59:55] Get input channel info proc start
[22:59:55] Get input channel info proc ok
[22:59:55] FInConvertor=ASIOSTInt24LSB
[22:59:55] FOutConvertor=ASIOSTInt24LSB
[22:59:55] Create audio assign proc start
[22:59:55] Create audio assign proc ok
[22:59:55] Create asio buffer proc start
[22:59:55] Create asio buffer proc ok
[22:59:55] Sound card buffer size :136
[22:59:55] Bloc size :136
[22:59:55] Set samplerate proc ok :44100
[22:59:55] Start Autoload
[22:59:55] InitLoadData :C:Program Files (x86)Sensomusic UsineWorkspace.wkp
[22:59:55] Workspace loaded
[22:59:55] Start Load Master
[22:59:55] InitLoadData :C:Program Files (x86)Sensomusic UsineDefault-Master.master
[22:59:55] Master loaded
[22:59:55] Start Timer
[22:59:55] MainForm Startloading done
[22:59:55] Begin application
[22:59:55] GhostPanel RegisterTouchWindow
[22:59:55] Start asio proc stop
[22:59:55] Start asio proc start
[22:59:55] asio started
[22:59:58] Stop asio proc start
[22:59:58] asio stoped
[22:59:58] InitSaveDataRewrite :C:Program Files (x86)Sensomusic UsineDefault-Master.master
[22:59:58] FinalSaveData :C:Program Files (x86)Sensomusic UsineDefault-Master.master
[22:59:58] InitSaveDataRewrite :C:Program Files (x86)Sensomusic UsineDefault-Remote.remote
[22:59:58] FinalSaveData :C:Program Files (x86)Sensomusic UsineDefault-Remote.remote
[22:59:58] InitSaveDataRewrite :C:Program Files (x86)Sensomusic UsineDefault-WavePlayer.waveplayer
[22:59:58] FinalSaveData :C:Program Files (x86)Sensomusic UsineDefault-WavePlayer.waveplayer
[22:59:58] InitSaveDataRewrite :C:Program Files (x86)Sensomusic UsineTempUsine.tmp
[22:59:58] FinalSaveData :C:Program Files (x86)Sensomusic UsineTempUsine.tmp
[22:59:58] InitSaveDataRewrite :C:Program Files (x86)Sensomusic UsineWorkspace.wkp
[22:59:58] FinalSaveData :C:Program Files (x86)Sensomusic UsineWorkspace.wkp
[22:59:59] InitLoadData :C:Program Files (x86)Sensomusic UsineTemplatesDefaultEmpty Workspace.wkp
[22:59:59] FinalisationUsine
[22:59:59] WaveFileCollection.Clearwaves
[22:59:59] WaveFileCollection.Clearwaves OK
[22:59:59] FinalisationUsine OK
Unread post by nay-seven » 12 Jan 2012, 23:05
Our download system ( when you receive your personal link by mail ) is linked to the last version on the server , not so easy to have several version on the download page .
Sorry for this inconvenience, but as I've said i 'll see how we can do.
and please use contact@sensomusic.org for bug report
lxegs
Unread post by lxegs » 12 Jan 2012, 23:33
ok mail sent with more tests, details ....
Unread post by nay-seven » 13 Jan 2012, 15:42
ok, 2 things :
I don't receive your mail , my fault it's a .org not a .com : contact@sensomusic.org
The previous version is available as download again.
lxegs
Unread post by lxegs » 13 Jan 2012, 18:24
ok mail sent
i will try with last stable version
thx
lxegs
Unread post by lxegs » 13 Jan 2012, 18:32
same crashes on the 5.70.035 version
i have reinstalled from scratch my windows box on christmas
do the software write some registry keys that can brick something ?
using usine as a vst in Live doesn't make Live crashing ....
lxegs
Unread post by lxegs » 13 Jan 2012, 18:39
I have found why it crashes : last week i have set the asio settings on 44100 Hz 24bits
changing to 16 bits and no problems at all....
Unread post by nay-seven » 13 Jan 2012, 19:23
ok, so the good news is that you found the reason !
lxegs
Unread post by lxegs » 14 Jan 2012, 01:04
Yes :)
of course i don't use 24bit at all, if i can help you to find the reason behind the crash....i' m ok to spend time
Users browsing this forum: No registered users and 922 guests
