As discussed earlier in this french topic months ago, a small thing that nerves me..:/
http://www.sensomusic.com/forums/viewtopic.php?id=3080
I would appreciate that the output of a track with a mono patch would behave in the same way in rack/all mode than in grid mode !
In one case, we obtain a centred signal in master (that's what I prefer), in the other case, we obtain a left output signal.
Is there any reason about this comportment ? :rolleyes:
GD
mono tracks with mono patch beeing centred in rackmode like in gridmod
I'm back...
www.gillesdimanche.com
This difference is normal because in rack mode we have to consider the input section (witch is stereo) in the audio flow chain.
Just add a second output on mono patch (make your patch dual mono) to solve the pb!!
Ok, I understand,
I didn't though that every tracks are in fact stereo track, even if there isn't any input selected on his top, then I imagine that it is a consequence of uSine principles.
Thanks Senso for the rapid answer.
I'm back...
