Can the computer keyboard be used for any of the messages listed in global remote panel ? It seems I'm unable to change the channel number from the default - 0. I'm assuming it's because the computer keyboard is not a midi enabled device. Hence probably a pretty silly question, but if you can confirm that would be great.
TIA
SA
Computer keyboard
Vincent
Hello StuartAmbiant.
But you're right, computer keyboard is not a real midi device!
So, if you want to affect computer keys to global remote (or any ctrl in your patches) just click first on the KeyLearn switch instead of the MidiLearn switch.
You can use any combination of keys. But be careful not to re-affect key-combinations already in use, it may be disturbing if you want to follow some of the examples given by Sensomusic: they may won't work anymore.
Just in case, save the actual remote config (file/Save as in the Global remote window), then tweak yours, then re-save yours with another name.
You can then also try right-click on any control you want to remote and tick "KeyLearn" (or "MidiLearn") before activating your keys (or midi controllers).
Hope it helps.
Rgds
Of course, yes.Can the computer keyboard be used for any of the messages listed in global remote panel ?
Hope it helps.
Rgds
Users browsing this forum: No registered users and 1271 guests
