Mouse Cam
CleverConQueso
Unread post by CleverConQueso » 10 Dec 2011, 01:06
Does anyone have a suggestion for the easiest way to record screen capture video with audio from Usine beyond pointing a web cam at your monitor?
-CCQ-
Unread post by nay-seven » 10 Dec 2011, 01:38
you can try hypercam
freeware : http://www.hyperionics.com/
caco
Unread post by caco » 10 Dec 2011, 21:59
Also CamStudio
freeware ; http://camstudio.org/
CleverConQueso
Unread post by CleverConQueso » 11 Dec 2011, 18:31
I've been using VNC. I don't see where the others (or VNC for that matter) will let you route ASIO into them. Do they? Or is there a trick or do you use one of that jack-type programs?
Users browsing this forum: No registered users and 437 guests
