Using customized bitmaps for GUI?
UsineHeaven
Unread post by UsineHeaven » 06 Dec 2011, 23:03
As I'm working to create a GUI for VST:s that can be used in Cubase & Ableton, I will need to use my own bitmaps. Is it possible in this version of Usine Pro & Esine??
Cheers.
Unread post by nay-seven » 06 Dec 2011, 23:29
yes, all background and Interface design modules can have their own bitmap.
here a personal example :
when you export as VST, the only thing you can't skin is the Usine header like in homing pad VST ( the panic button, sync isolate, cpu and memory vu-meter..)
It's something like Reaktor ensemble if you use it..
UsineHeaven
Unread post by UsineHeaven » 07 Dec 2011, 01:12
Fantastic man! Thanks for clarification.
bonello
Unread post by bonello » 08 Dec 2011, 01:24
Is there a tutorial that I can follow about using Bitmaps to build GUI?
Cheers,
waolelaid
Unread post by waolelaid » 08 Dec 2011, 04:54
Friedrich Nietzsche
Unread post by senso » 08 Dec 2011, 09:14
waolelaid wrote:Hi ,may be this one
http://www.sensomusic.org/wiki/doku.php ... te_bitmaps
it's not really GUI tuto but more for bitmaps manipulations in real time.
bonello
Unread post by bonello » 08 Dec 2011, 09:15
Thanks for the link.
So is this the way to create a moving fader or a turning knob?
This is what I am trying to achieve - custom controls, but I am not sure how the images have to be assembled to display the motion.
Cheers.
Unread post by nay-seven » 08 Dec 2011, 09:20
here 2 others ones , and don't hesitate to ask more if needed :
faders
crreate a knob
bonello
Unread post by bonello » 08 Dec 2011, 10:29
This is all very helpful.
I will take some time to explore and experiment.
Thanks a lot.
Cheers.
waolelaid
Unread post by waolelaid » 08 Dec 2011, 19:02
Hi and sorry i didn't understand the question :)
good evening
Friedrich Nietzsche
Users browsing this forum: No registered users and 452 guests
