[large]Usine 5.70.035 Update[/large]
Important bug fixed on the HID Device module (which appears in the 5.70.034); should be updated if you use it.
fixed bugs
- the HID device module doesn't work properly
see
Release Notes
- senso
gercha1
merci pour la rapidité,
gérald
gérald
L'orchestronique - foSolo
http://www.arbre-canapas.com/l-orchestr ... ideos.html
