Question or two about load patch module...
Load patch module is a great feature and really saves a lot of memory and cpu but...
when i use load patch module in lets say track 5 and activate it... it deletes everything i made on track 1 and loads the patch?
Of course i can move everything from track 1 to track 2 and so on...but it really affects hours of maping for channel 1 (track 1).
It would be great if a load patch module can load patch in track where load patch module currently is (track 2,3,4...)
Another thing with load patch module...its not working at all when i create vst version of my project.
Cheers!
Load patch module
have you try to use the current line and current track modules linked to the inlet of the load patch one ..?
i think not...
i used load project module and it works...but its too much work when you have too much projects or patches...
can you please explain more about current line and current track modules what they do.
current track module is not working...
thanks for quick response.
cheers!
cheers!
By default, when you drag and drop a load patch module, he has default values: line 1 , track 1
so it's the reason of your problem
you have to set the line/track you want
you can also use the current line and current track module who detect where they are :
thanks a lot!
i cant believe i didnt see that
cheers!
cheers!
