sequence with start and ending points
tanabarbier
here an old one I've:
download
download
tanabarbier
It was indeed a very simple thing to patch, thanks a lot, it is just what I needed !
I've tried to do the sequencer patch purposed by Nay-Seven to restart accordingly to the auto restart Synchronization but I have an issue.
The sequence don't want to restart at the first step, it always start with the second
I'm quite new to Usine so that should be a dumb mistake, but I can't resolve it by my own.
Thanks.
here's the modified patch:
Download
Thanks.
Download
strange, works fine here...?
Set all the notes to low values except the first note , you don't hear the first one..?
Thanks for your quick reply Nay!
I've just tried your Tips but it still don't want to play the first note on restart,
I mean the first note is only played after a the first loop iteration.
It's pretty confusing because the cursor is well positioned at the beginning of the sequence.
I've tried different system setup but nothing to do.
ok, i understand now, in your clock beat sub-patch , change your 1 to 0 module for 0 to 1 , will works
Clearscreen
Just listening to the mix on your site silent - like it a lot! Dl'ing now
Users browsing this forum: Google [Bot] and 37 guests
