I have a couple of wishes that hopefully are easy to implement:
1) A volume control sound files in the Browser. When you try to have "conservative" levels within in workspace but playing through a loud PA, a sample played at unity gain can come as an unpleasant surprise when double-clicking a file. Maybe also as a default preference value in Global Setup.
2) Better visibility of the patches' On switch. The change in background colour from white to ligth yellow is very subtle, at least for my old eyes. Just changing the captions to eg On/OFF or ON/off would help.
A couple of wishes
there will be a global "pre listen level in the Setup/Audio Out/"bsork wrote:1) A volume control sound files in the Browser. When you try to have "conservative" levels within in workspace but playing through a loud PA, a sample played at unity gain can come as an unpleasant surprise when double-clicking a file. Maybe also as a default preference value in Global Setup.
version 5.70.034 and above
added a new couple of lines in the control panel layout to adjust the size of the ON/OFF buttonbsork wrote:2) Better visibility of the patches' On switch. The change in background colour from white to ligth yellow is very subtle, at least for my old eyes. Just changing the captions to eg On/OFF or ON/off would help.
Thanks a lot!
