Button issues
TFF
Unread post by TFF » 01 Nov 2011, 21:14
I've got a button in my patch's UI that I want to operate two ways.
1. If I click and hold the button, it will send it's ON value until I release the mouse. This can be done with the "mouse dwn" parameter.
2. I also want to be able to assign a MIDI or Key learn to the button, and have it respond as it does to the mouse, sending it's ON value until I release the button.
Is there anyway to do this with a single button object?
Best,
-Zach
Unread post by nay-seven » 01 Nov 2011, 22:22
not easy with a button, but you can use a workaround with a switch , used as a button
important: right click and choose remote mode absolute
this way you can use it with key and midi learn and with the mouse
joffo78
Unread post by joffo78 » 02 Nov 2011, 06:53
Very clever nay !
I wonder if i could find myself this solution .
