videodetect module
lucenay71
Unread post by lucenay71 » 01 Nov 2011, 19:00
I've tried your patch Videoballsynth dx with my webcam it works well with Nay Seven Synth. I would like to know how can i patch the video detect module to a sampler to be able to command samples in random mode when somebody walks past the webcam. ( And if it is possible with a random pitch too)
thanks you very much for the help.
Unread post by nay-seven » 01 Nov 2011, 19:41
here a really simple way :
then, depending of the situation / camera / light condition you can use different solution
for example, you can use a A>B module linked to the surface outlet , this way only big zone run the sample
and so...
Users browsing this forum: No registered users and 118 guests
