Simple Griid-like Touchscreen Monitor Patch
K8.
Unread post by K8. » 26 Oct 2011, 12:09
Hi everybody,
I hope that you can give an hand with this! I have a 23" inch touchscreen monitor, now working on mac os using touch-base drivers, but I can't find a solution to a very (simple?) problem: I bought it specifically for use in live situations with ableton live, together with some physical midi controllers, so i need it JUST TO TRIGGER THE CLIPS.
All i want is a bunch of clips over 16 tracks (i play my own stuff live, so i use stems of drums, bass, etc... to be able to "remix" things live) and the scene launchers on the right, nothing else. But the clip triggers are too small even on a 23"!!! totally unreliable for a live performance...
This is why I'm thinking aboiut usine pro and i'm now checking out the free version. I just need a patch that will let me do that without getting into stuff that invloves a proper learning curve. Big clips triggers, name of each clip reflected on each trigger, scene launchers. That's it.
I know that this is a shame, because usine looks like a beautiful software to learn, but i'm a full time producer and sound engineer, i really have no time for that :( I'm struggling to get this live project on the go and keep the "artistic side" alive.
I would have really liked to stay on mac os for various reasons, but if i have to use usine on windows or WHATEVER i'll do it, any help is really, really appreciated. I'm up for buying usine pro or even paying anyone who can provide such a patch (even for max for live, which i bought, sorry if it's not the best place to ask...hope it doesn't sound unpolite) that will let me do this without struggling :)
Thanks so much
Unread post by nay-seven » 26 Oct 2011, 14:39
hello and welcome K8
there's an add on for live from 23fx, can't help you with but maybe if you know well Live, can suit your needs
http://sensomusic.com/forums/viewtopic.php?id=3182
now if you only need launch clips , maybe a simple midi object + virtual midi cable can works..?
you can find examples in the browser Modules/midi/midi interface objects
K8.
Unread post by K8. » 26 Oct 2011, 16:02
hey, thanks for the reply. That apc patch looks perfect! i'll see if i can ghet it to work and let you know :)
Users browsing this forum: No registered users and 426 guests
