I'm trying to convert audio to midi (audio to midi udine module)
I play the saxophone in the mic and usine convert it to midi.
and the midi out active a a kind of saxophone sampler.
everything works fine if I play this melodie : G F E D C
but if I repeat the C then it is not detected
here is an audio link of this :
http://rennes2100.free.fr/divers/audio% ... nput-1.mp3
I tried to change the midi filter inside the module,
but it doesn't change anything
maybe is there something to change in the settings ?
audio to midi module
thanks for the mp3 file, you're right
not sure but maybe something to do in the script named filter>
if a script guru can check..?
I wanted to do that for a long time, I have uploaded a new audio to midi sub patch made with the phase vocoder.
It gives very good results but more cpu than the old one.
http://www.sensomusic.com/forums/upload ... tch%29.pat
You have to upload and install the phase vocoder addon :
http://www.sensomusic.com/downloadaddon ... %200.5.rar
feedbacks welcome!
feedbacks welcome!
I try to test this patch but there is an ''internal error'' ...
It is the same thing with the patch ''Pitch Shifter'' and ''Spectral Delay'' from the Phase Vocoder Pack 0.5. Usine always crash with ''Spectral delay''.
Perhap's Phase vocoder Pack is not correctly install ? There is a lot of file that i didn't know in the pack and no instruction about how to install ...
Thanks.
Thanks.
Just extract the contents of the patch and bin dir in you user library, must work
